I have a software problem.
katrei.mate15d402ed
Hello. The app keeps switching from "default" mode to automatic "overclocking gpu" mode. Can you help me? computer turns itself off.
I'm sorry I don't know much English.
TR: Merhaba arkadaşlar bugün başlayan bir problem yaşıyorum Türk bir arkadaşımız varsa yardımcı olursa sevinirim. LoL oyununun clientini açarken sürekli yazılımın modu değişiyor.
Farklı oyunlarda oluyor mu halen denemedim ancak bu problem aşırı canımı sıkıyor. Bilgisayarı geçen ay aldım
Rx 6800
Ryzen 5 5600
bilgisayarın donanımları.
Alan J T
Demon God Gone Racing Forza MS Is live
Rx 6800
Ryzen 5 5600
DO you have MSI Center or Afterburne installed
Please use Google translate if you need to
Google Translate
MSI Center veya Afterburner kurulu mu?
Gerekirse lütfen Google Translate'i kullanın
katrei.mate15d402ed
While playing the game, I suddenly encountered a black screen. It was like that when the computer was turned on. Ah, I regret buying AMD.
Alan J T
Can you run AB with Furmark and see what it shows I think you may have a GPU fault
as no voltage is showing
Your GPU should have about same results as mine as I have the RX 6900XT
Make sure you have enabled the setting as well
katrei.mate15d402ed
Thank you for your help.
However, on Friday, I sent the product to the technical service.
I hope they make a change.
I am waiting for a reply from technical service.
If something bad happens, I'll write it here.
