i need help with my new msi 48x cd writer
S
sellout5fe
Guest
i installed my new msi 48x cd writer to my computer which came with nero burning rom.
for personal preferences, i would like to install and use easy cd creator. i have not been able to successfully set upo the cd writer to be able to use it with easy cd creator. i was wondering whether anyone knew if the writer was even compatible or what....any help would be greatly appreciated....i hope someone knows and can help!!!please!!!!
thanks alot
stephen
I
ibskip
Guest
Are you using easy cd 5 platinum ?? Have you done the driver update ?? What is your operatring sys ??
S
sellout5fe
Guest
i have easy cd creator 5 platinum, and i tried to do the driver update or whatever on the webpage, but the MSI 48x cd writer or (DragonWriter) was not on the drop down menu. i am using Windows 98 also.
Wonkanoby
GENERAL OF THE ARMY
gave up on easy a good while ago but it gives you option to just type in a drive to get to updates im sure
K
kashmeer
Guest
It is not supported by EZCD yet, give it a bit of time...
I happen to like Nero better, once you get used to the feal
