I need monitor
MartinLtu
good day my computer ryzen 5 5600x and RX 6600 XT GAMING X 8G, I would like a 27-inch game monitor what would you advise?
badboy2k
Depends what you plan to do with it?
are you planning to do:
Gaming
Watching Videos
Editing Videos
Doing Photo Work
Firstly, personally, I'd have a look through the review sites, youtube etc and see what comes out as a best pick/buy for your budget. The other thing is, what is available in your country? Ideally, you'd want to see a monitor in action but realistically, not always entirely possible. Also, what might seem a mind blowing monitor to one individual, you might have a different opinion once you're using it. Also, it will be your graphics card which will dictate what kind of monitor is worth buying. What graphics are you using?
MartinLtu
man if the monitor can't offer it, then at least tell the data for example 27 inch 1440p what mhz is best and similar gpu rz 6600xt
Alan J T
Demon God
Looksy here
Any monitor functions. Depending on what you're pursuing.
You decide how to proceed. I would suggest 1080p if you're okay with it. Although 1440p is prettier, you might not be able to play some games at high framerates at that resolution.
