Arala Cran
- Mar 10, 2025
Sorry to bother everyone but I've purchased a MSI-based Gaming Desktop around November ~18 or such in 2024 going into 2025 but now I have a major set of problems of a scene that happened.
First, it was working fairly well except giving off a quick error or such every time I shut it down; however around last week or so, Windows 11 has been acting very abnormal in a bad way. I was greeted with a black screen that didn't load yet the cursor would move or pressing shift several times brought the sticky keys popup, but no deal. This happened for a day and a half but it worked again after several vexing resets and waiting in a panic. Two days ago though (last friday) is a different story which gotten much worse:
It started the Windows 11 not loading problem but this time did not work till the next day by chance and so I changed the automatic background switching off expecting that was a Windows issue to the MSI background manually to not change or cause lag on loading and restarted but that was a mistake apparently,
-PC kept starting the BSOD problem over and over,
-Windows Repair did not repair anything and looped several times,
-I could not "reset windows" because it kept saying "There is a problem, you cannot reset windows" (meaning no restore, no factory resetting windows with or without file loss)
-I had enough and went into the BIOS and executed a System Erasure in expecting something bad was on the drive from nowhere and now Windows won't even appear, just the BIOS loop...
Is there any way to fix this or is this the end of that desktop PC?
