I am very confused now. I have 2 USB 2.0 device, 1 USB 2.0 HUB (4 ports) and 1 USB 2.0 Card reader. When I connect the USB Card Reader to any of the 8 port available (I am using 865PE Neo2 Series Mobo), XP did not complaint any error. I believed that it is able to communicate at 2.0 speed.
However, when I connect my USB Hub to my PC, XP will complaint that the USB device can perform faster if it is being connect to a Hi-speed USB 2.0 port. When I click on the bubble, the dialog box will display that all the ports are unused, which is not correct, as I have at least 1 port in use, i.e. my USB Modem. To add further confusion, when I connect my USB 2.0 Card reader to this USB HUB, the XP will also give the same message.
So, I don't know where the problem actually lies, is it the hardware or the software? Do note that I have removed PIN 10, and I still encounter the above messages.
I tried to use the UVCView to see what is the configuration. How do I interpret the information? Is there anyway of telling whether the USB device is 2.0 or 1.0, and at what speed is the device communicating with the PC?
Thanks in advance.
