A lot of posts on pin 10, but all need to read the USB specification, in particular the part on USB2.0.
Dare I say you all have it wrong.
In the pre-specification developed by Intel pin 10 was to be designated for overcurrent, but in the official specification it is for shield ground.
Prior to USB2 there was no requirement for the cable to be shielded, but with the much higher data rates under USB2 the cable needs to be shielded to stop errant noise from climbing on to the data lines and forcing misreads and re-requests of data. The continuous connection of the shield is accomplished via the metal shell of the connector. That is you have the 4 pins inside if you look in the end, plus the outer metal shell. That spec is to be followed from origin to termination with the exception being at those points where the wires break out without a USB2 connector and there they will be wired to the device. It has been a long time since I went over this with the board and read the spec, but I'm now thinking there may have been one exception and that was for a mouse. Check if you like.
It became a question for me when I discovered my case was not using pin 10 and I decided to check the facts. And despite it seems to have fixed a situation for some of you, one user in the forum for my case had an issue with front port not working for something, I no longer remember what, he picked up on my posted findings and posted back that modifying the case cable to connect fixed his problem. In our case, the harness floats at both ends, that is at the front port where the shell of the plug makes contact, it was connected to nothing.
I can not tell you who did not follow the USB Board Specification in each of your situations. It is possible the MOBO was not designed properly. One easy way to verify it is, check that pin 10 on the MOBO headers use the same physical plane as the shells for the USB connectors on the back of the board. They all should be signal ground, which may or may not be the same as power ground.
It might be your case maker if the ports for the front were installed by them.
Nor can I tell you exactly how much impact will occur if your shield is not properly terminated. It can vary according to the device plugged and it's demands. If it is USB 1 or 1.1 it should have no real effect because shielding was not required then. It will in part depend upon how much noise is getting to the data lines forcing resends. BTW, the data lines are a twisted pair.
Norman
Norman
