Increase fan speed on msi notebok
edwin.waer15b002e7
I have an "old" msi GE62 6QC Apache notebook that runs hoter than i like most of the time and i have done the bios uppdate and it improved it some but still not what i would like.
I Have read about something called "Msi silent option" that allowed you to increase the fan speeds. But i cant find the program anywhere now like its wanished from the world completely.
Is there some way i can increase my fan speeds no a mor resonable level?
I know i can push my turbo fan button but thats just to loud fore the most part. Would be nice with a happy medium beteen the turbo button and what the cumputer sets the fan speed to.
drek4
Active member
PRIVATE FIRST CLASS
Dragon Gaming Center
Silent option
edwin.waer15b002e7
Silent option
Both links takes me to the same place and i don't find the silent option there, Am i missing something?
I hav ethe msi dragon gaming center on my computer and iv hade it since day one as it was installed on it from factory. But i havn't found any fan controll in there.
What is a safe temperature on an msi notbebook ? im reaching just over 90c on my gpu and almoust the same on my cpu
drek4
Active member
PRIVATE FIRST CLASS
All my laptops with DC I can customize my fans.
Have you uninstalled the one you have and downloaded the one in the first link?
Low 90s in games is fine for CPU, for GPU it's a little on the high side.
hchg
Active member
LIEUTENANT COLONEL
Personally, I would most suggest you check the actual degrees of the CPU & GPU.
As the model you own has been out for a longer time, it's possible that the thermal grease needs a re-paste or clean the fan dust.
Using a fan control app will not provide much help if the higher temperature is given by the aging thermal paste.
Here you go the link for downloading the silent option app: Silent Option
Get the Silent Option V1.0.1603.3101 for your model.
A 90 to 95 degree of CPU running under heavy loads is common on MSI's notebook, as the processors are often set to the highest state by default, if you're looking for a temperature lower than that, you might want to set a lower performance for the CPU.
edwin.waer15b002e7
Got the new version of dragoncenter now from another msi laptop but it seems to work. I had the old version of dragon center before despitte that i have uppdated it not to long ago. That version didn't alow me to controll fan speeds:( the new one does so so far so good. Will se if i decide to replace thermal compund or if a better fan curve does the joob good enough for now.
Thanks for the help
