Installed MSI Geforce GT730 - showing blue and white lines.. pls help!
vmldasblr2160502ee
Installed MSI GeForce GT 730 GPU on my sys ( Mother board - Gigabyte GA-H61M-S, i5, 16 Gb ddr3 ram technology, Smps 500w, OS - Windows 10 prof edi. ) after connecting monitor cable the monitor displaying everything in blue and white lines. Installed latest driver from MSI and slso tried old version of driver, still showing in blue and white lines (attaching image). In device Manager we can see the hardware but it has a yellow waring triangle "windows has stopped this device .. code 43". Please help to ressolve this.
Hi
Try a different monitor, and a different cable. Perhaps you can test the card in different system.
Though looks like a faulty card.
Cool, thank you very much for the reply will check using another monitor and cable. However I tried using another old graphic card (XFX ATI Radeon HD6770 1 GB DDR5) got the same issue - thick red stripes after installing gpu and after updating driver sys stopped booting.
Hm that's an interesting issue.
I'd go with testing different monitor and cable. Also odds are, some short is caused by the chassis, so try with the system out of the case as well.
Possibly there is something wrong with the PCIe port on your motherboard. Or with the CPU.
Faulty card could be displaying artifacts like this. But if another card gives you the same result, then it may be anything else in your system.
Without more hardware to test it's just guessing game.
