Intel(R) Ethernet Connection (12) I219-V, This device cannot start. (Code 10)
@Svet
I have a msi pro b660m-e ddr4 also having the same problem plz do help me
i also tried reinstalling drivers atleast 4 times but still the same error
usb1284
CORPORAL
SVET can you tell me how to enable 1219-V to get internet connection, please?
Administrator
What hardware you have? and what issue with the ethernet? if you have different issue, best open new own topic for that.
zhelev679131602b9
Hello , I've got the same problem
Intel(R) Ethernet Connection (7) I219-V This device cannot start. (Code 10)
Any solution about it ? Thank you
MSI Z390 Gamer Pro Carbon AC suffering from this dreaded This device cannot start. (Code 10).
Repeated driver reinstalls no avail. Also the sound card and PCI 0 failed as well. @Svet Any help?
Also it appears this is a fairly common enough issue with dozens suffering the same error. What is the root cause of these failures?
Just wanted to report that I had to update from Windows 21H2 to 22H2 to fix this problem as I also had the WIFI and HD audio device fail. I had to download the Windows Update Assistant as the built in updater would fail. The update would succeed but would reboot to black screen and I had to let it go for another 15+minutes.
sarkody15b202dc
Motherboard: MSI Z590 Pro WIFI
Have been dealing with the same issues in this mass thread- This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful.
Repeatedly uninstalled, installed drivers, my ethernet network device, updated BIOS. Troubleshooted through Intel support over the last several days to no avail and was recommended to go here now. Feels like I gone through numerous methods over and over at this point and just am out of ideas. Hoping you can help @Svet
