Intel(R) Ethernet Connection (12) I219-V, This device cannot start. (Code 10)
fuady152d02d0
I am having a problem where my ethernet driver isn't working
I have tried reinstalling the driver by deleting it and restarting my pc, downloading driver from both msi site (I can't install the one from msi site because it said that network adapters are not detected or something) and intel site, and even reinstalled my windows, but none of them fixed this.
here are my specs
Motherboard : H410M PRO VH (MS-7C89)
Processor : Intel I5 10400f
Graphic : RX 550
Windows 10 Pro Version 20H2 OS Build 19042.867
Click Bios 5 ver E7C891MS.180
hi @Svet ...same problem, device can't start code 10. but i'm using an asrock b560m mobo, bummer. i tried using the intel ethernet flash firmware utility, but it seems the firmware is corrupted/no firmware found. i can't find any on the net where i can download a backup firmware for the i219-v... hoping you can help me, thanks
Please check it with Asrock support.
Hey @Svet
I got the same Problem on a MSI pro b650m-p Mainboard with a 7950x3d CPU
A fix for this would be nice.
Kind Regards
Marco
Check PM
Hi @Svet
I got the same issue with my Trident 3 bought in 2020 with i5-9400F CPU and MS-B9201.
In the first one or two years, the network was ok. Then, the network dropped frequently from hours to days. I reinstalled the driver or rebooted several times during that period. And these methods worked fine. Then later on, the network was quite stable only with a few drops within weeks. But from yesterday, both methods did not work and I found the report about error code 10.
Thanks in advance for your help!
Did you flashed the BIOS prior to this issue?
@Svet
Hi, I noticed you keep sending PM's to people with this problem and I have a issue with my 1219-V Ethernet Adapter it's giving code 10. I've tried power flushing, updating bios, disabling/enabling in Device Manager, uninstalling and checking hardware, I am not sure what to do anymore. Can you help me?
Asrock B660M-C Motherboard with a Intel gigabit ethernet lan adapter it's 1219-V
I7-12k
Yep, check PM
Good afternoon, I have a problem with the motherboard msi B650 Tomahawk wifi lan cable port since it doesn’t recognize the lan from the port but it does recognize it when i plug it in with an adapter in a different one if you could find a solution, i will appreaciate.
Thanks in advance🙏🏻
@Svet
I7-12k
You have to ask your mainboard vendor for this issue.
Worked! Thank you!
:emot-tip-wink:
Thanks in advance🙏🏻
Best open new topic for troubleshooting in correct forum area.
Hi @Svet
Could you please help me? I have the same problem with code 10 on Intel ethernet.
MSI H310M Pro m2 plus
Yes, check PM, and reply me with S/N of your board.
Helo @Svet , can you please help me with installing ethernet drivers on my Msi b660 m-e ddr4..After updating bios to latest version,,ethernet adaptor not working anymore..
PM me all details, include S/N of your board.
Windows 10 Pro
Msi b660 m-e ddr4
16 Gb ram
Mobo S/N : 601-7D46-060B220xxxx
Problem: Intel ( R) Ethernet Controller (17) l219-V
The device cannot start ( Code 10)
Operation Failed
The requested operation was unsucessful
