Intermittent Red + Yellow solid lights, failure to POST on MAG B650 Tomahawk Wifi
botany.spore-7y
Hello, I have had a recurring issue I’ve been dealing with for the better of two years. Btw, I’ve had this PC for 3.5 years, so I went almost 2 years without issue.
For an unknown reason, on boot, I (often) get a red+yellow light on my mobo, with a failure to post. Sometimes, however, the post will randomly succeed, which has confused me for a long time.
I am writing this today after I have just installed a brand new PSU because I thought that might finally fix my issue, to no avail.
Specs:
Mobo - MSI MAG B650 TOMAHAWK WIFI
BIOS VERSION: 7D75v1R3 (2026-09-09)
GPU - NVIDIA RTX 4070 TI
CPU - Ryzen 9 7900X
Cooler - Noctua NH-D15S
RAM: G.Skill Flare X5 64 GB (2 x 32) DDR5-6000 CL30
SSDs: 2x Samsung 980 Pro 2TB PCIe 4.0 X4
I also want to mention that the motherboard had no bent pins at the time of install a year ago (after I bought a replacement to see if that would fix the problem, which it slightly remedied). The RAM is new as of 2 days ago, and I have a known-good single RAM stick that has been tested with a RAM tester I can try if advised, and the power supply is brand new as of today.
Also I should note, I mentioned I have 1 known good ram stick.
I was using ONLY that stick in A2 for half a year, as my other stick was causing blue screens which ceased when I removed it. Meanwhile, I still had POST issues. I don’t believe my RAM is the cause of these issues due to this.
Random CPU+DRAM LEDs, this is the most annoying problem on AM5, often times it happens for no apparent reason and it's difficult to solve.
Now this is surprising. So you are saying, you had B650 TOMAHAWK WIFI (1), which developed the issue after ~2 years, then you bought B650 TOMAHAWK WIFI (2), which only led to a slight improvement, but not a fix? Well, apart from the fact that semi-randomly buying new hardware is not the best way of troubleshooting, this is already pointing to the CPU, if you ask me. The CPU is the one housing the CPU cores and the memory controller, and thus could be what is triggering those LEDs.
In some cases I also suspect an imperfect contact between the CPU and the socket pins to be the cause for these LEDs, but I don't know if this is still valid if the board was already replaced once. I mean, that Noctua will be putting a bit of strain on the socket area from its weight alone, but on a new board, it shouldn't cause any issues.
Did you do any tests on the other stick? You'd need to find out if the other stick was faulty, or if the dual-channel operation become unstable somehow. So at the very least, I would've tried both modules individually in slot A2, running Memtest86 from a USB stick to see if one of them causes errors in there. Then you could RMA the kit, most brand-name RAM tends to have a lifetime warranty.
Yes, I don't think the RAM is the cause either, but it might be unfortunate collateral damage, if something went south with the CPU somehow. I believe that with the board, the PSU and the RAM being ruled out, you are looking squarely at the CPU now, and it would be best to source a known good AM5 CPU for a test.
Since we're at it, which model?
I included this just incase it would be important for anything at all, but most likely it was a placebo effect. Like I described, the intermittent issue was basically up to luck whether or not it would occur or if it would post like normal.
I can see that being the case, however that would have to mean that the current, new motherboard came in damaged, or the cooler caused damage after I put it on, which lead to the same intermittent issue, which is definitely possible but odd.
I don't know if you saw (since it's not included in this reply), but I mentioned that I tested both modules of my original RAM kit in a memory tester. The one module, which I was using in A2 for the past 6 months, had no indicators of any issues with the module according to the tester. However, the module which I suspected of being the result of my blue screens (the one I removed), had many unlit lights on the memory tester (link to the amazon page here), indicating it had many issues, which lines up with the blue screens which ceased when I removed it. I'm not sure what other tests you might be referring to in regards to my original RAM kit.
Unfortunately, I do not have any spare CPUs at home to test. I could, however, purchase a new one. However, I am not sure whether or not I should upgrade, or purchase the same one I currently have. I would appreciate your opinion if you'd like to share, and/or recommendations.
Also, since I'm already asking for your opinion, you mentioned that you think the weight from my cooler might have lead to CPU related damage, do you think I should buy a different cooler? If so, again, do you have any potential recommendations? You don't have to find me any recommendations, but I've seen you active on here quite a bit and feel like you might have some good ones off the top of your head.
I knew I forgot to include something in the specs. The new PSU is a "be quiet! Pure Power 13 M 1000W".
Also, here's the original RAM kit and PSU:
Original RAM Kit - Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36
Original PSU - Corsair RM1000x (2021) 1000W
Small update;
I just tried cleaning the golden fingers on my faulty RAM stick to see if it would help, and I did not see any changes in the lights on the RAM tester. That stick is likely unable to be fixed.
Also, I should mention that all of my purchases were done on Amazon, likely without warranties, and the original build is over 3.5 years old. So, there is likely no warranty for me to get any replacements for anything to my knowledge (or maybe, there is something that you know about which I don't).
Lastly, I am currently writing this while on my PC, using my new 2x32gb RAM kit, so these sticks are both likely fine, but I still have my old vengeance stick which is good for testing if necessary in the future. I think with all of the info gathered it may very likely be the CPU, so I may look in to ordering one soon. I suppose I will be keeping my new RAM kit after all, the upgrade is nice (also 16 GB from the singular functional vengeance stick was miserable)
I’m going to test one more thing tomorrow morning hopefully (or night if I don’t have time) and then I think I’m going to order a new CPU, i’ve already decided I will reorder the same one as the few upgrade options available aren’t really upgrades, or are expensive for small benefit.
Yes, it's very important to know if the board was replaced already with a new identical one. If the problem keeps happening, it means the board as a sole cause can be ruled out. It's either something caused by another component, or in combination with the board (but cannot be solved by replacing the board). Outcomes such as this are why you typically shouldn't buy new hardware just because you suspect it being the culprit. The first step is always methodical troubleshooting where you try to narrow it down, ideally to one component. So, replacing a component, either through RMA or buying a new one yourself, is the end result after having done proper troubleshooting, when you already narrowed it down a lot. Otherwise you risk wasting time and resources.
For example, the PSU has a low chance of causing CPU+DRAM LEDs, the main thing a bad PSU could cause is the system not powering on at all, or getting just the CPU LED - as there is no PSU LED, but it's the earliest possible fault the board can display. When you additionally have a nice PSU model like a Corsair RM1000x (2021), and not some low-quality or old model, then it's not really advised to buy a new PSU in hopes of fixing this issue, because the chances are quite low.
Yes, I saw this from you about the RAM: "The RAM is new as of 2 days ago, and I have a known-good single RAM stick that has been tested with a RAM tester I can try if advised,", and then "I was using ONLY that stick in A2 for half a year, as my other stick was causing blue screens which ceased when I removed it.".
I was not sure what you meant with "RAM tester", and I must confess, after checking it out from your link, I haven't seen such a RAM tester before, and it's not very common. It's an interesting device, it tests the individual contacts / data lines on a purely electrical level, I wonder how reliable this detection is. Seemed to have worked here.
Now, you don't really need such a RAM tester, perhaps that's why it's rarely seen. Your PC can already tell you everything you need to know. If you check my RAM thread under 5), I list some RAM tests, I mainly use Memtest86 to find a defective module. This is a tool that boots from a USB stick, via the F11 boot menu (pressing F11 where you would press DEL for the BIOS, then selecting the first partition of the stick to boot Memtest86). With a defective module, it should show a bunch of errors pretty fast. So you put each module into slot A2 individually, as that is the first slot to be populated with a single module, then you can run Memtest86 for each.
What is the main priority? Gaming? Then the Ryzen 7 7800X3D for example. The X3D models do particularly well at gaming.
You have one of the best coolers, and me being all-Noctua too, I certainly appreciate seeing a good Noctua cooler in use. And this cooler should not cause any issues, unless there is some very weird design flaw in those boards. So no, I wouldn't say you should order a different cooler. Also, all the other air coolers that can cool this well would weigh just about as much, too.
That's a very good model, but yeah, probably an unnecessary purchase.
They are gold-plated, and gold does not corrode. It's possible that some dirt/dust has gotten on the contacts somehow, but I have yet to see this "finger-cleaning" solve a significant issue. Still, since it's such a low-effort thing to try, I will usually not remark on it when it's recommended by someone. Even if the chances are slim, it might be worth a quick try.
All Corsair RAM modules/kits have a limited lifetime warranty. "If your Corsair product is not operating in accordance with its published technical specifications, it will be replaced at Corsair's expense." You may receive a refurbished replacement, but it should be in full working order again. All that's required is to contact Corsair with Serial Number & Proof of Purchase.
In this day and age of horrendously inflated RAM prices, I would certainly RMA that kit.
First I would check what the main use cases of this system are. If gaming is high on the list, then I would recommend an X3D model, they run rings around the normal X models when it comes to gaming.
I started a ticket to RMA the Vengeance RAM kit, and I ordered the CPU, I chose a Ryzen 7 9850X3D since it’s for gaming. Will work on installing the new CPU either tomorrow night or the morning after.
Keep in mind that first training can be a long process, which is easily misstaken for another problem first couple of minutes. Especially with that 9850x3d.
This is very true.
I remember, especially early days of AM4 platform, when I assembled my first AMD system I was close to panicking as it took 10 minutes to boot first time 😂
Hmm, wondering how long the original motherboard was on an earlier BIOS with the SOC voltage exceeding 3.0V
This may have done some minor damage to the CPU
If the new CPU clears up the problems and everything works fine, I would RMA the R9 7900x.
I already looked into the warranty, it's out of warranty as it's been over 3 years (i purchased from amazon). I never updated the bios on the original MOBO, and I only updated bios on the current MOBO a few days ago. I don't remember what build I had on the original, maybe some 2022-2023 build, but the current MOBO was on some 2024 or something build originally.
Yep, very good chance the CPU is damaged due to SOC Voltage
Good point, Alan. And who knows, maybe this even played a role in ultimately damaging one of the Corsair RAM modules.
And it's another stark reminder that one shouldn't completely neglect BIOS updates. Every once in a while, there can be a very important fix among them.
back for another update;
i completely forgot about thermal paste.. so I just ordered some. luckily I have prime, so they say it will get here before 6 PM (upwards of 6 hours…) but once that arrives, I’ll be able to finish building
also, the pins are perfectly fine
You can fit the hsf without paste to do a quick test run. When the paste arrives later today you can refit+paste. If this cpu doesn't work either you won't waste paste.
