botany.spore-7y
- Oct 11, 2026
Hello, I have had a recurring issue I’ve been dealing with for the better of two years. Btw, I’ve had this PC for 3.5 years, so I went almost 2 years without issue.
For an unknown reason, on boot, I (often) get a red+yellow light on my mobo, with a failure to post. Sometimes, however, the post will randomly succeed, which has confused me for a long time.
I am writing this today after I have just installed a brand new PSU because I thought that might finally fix my issue, to no avail.
Specs:
Mobo - MSI MAG B650 TOMAHAWK WIFI
BIOS VERSION: 7D75v1R3 (2026-09-09)
GPU - NVIDIA RTX 4070 TI
CPU - Ryzen 9 7900X
Cooler - Noctua NH-D15S
RAM: G.Skill Flare X5 64 GB (2 x 32) DDR5-6000 CL30
SSDs: 2x Samsung 980 Pro 2TB PCIe 4.0 X4
I also want to mention that the motherboard had no bent pins at the time of install a year ago (after I bought a replacement to see if that would fix the problem, which it slightly remedied). The RAM is new as of 2 days ago, and I have a known-good single RAM stick that has been tested with a RAM tester I can try if advised, and the power supply is brand new as of today.
Specs:
CPU - Ryzen 9 7900X
