is my RTX 2060 Super Gaming X running hot?
kaan3215w14dd02cb
Hello. I am using this product nearly for a year. It idles at 53 degrees celcius and when it's full load on games (if gpu usage is %94-%100) it always boosts itself to 80 degrees. So when i play RDR2 - GTA V - Assassin's Creed Origins or Odyssey (or whatever uses gpu like %94-%100), it's always 80 degrees celcius. Yes it boosts itself to 1900 or sometimes more mhz's. Will this issue reduce my product's life span? It's getting harder to get a new graphics card in Turkey everyday. So i need to use this product as long as i can. Thank you and sorry for spelling mistakes if it happened. Im not native.
And yes if you'll ask, i have warranty
Peti0127
80 degrees is good, that idle sounds a bit high for me, my 3080 and 1080 idle between 36 and 41 degrees
80°C is ok and not really hot. Still the card could do better. Check the airflow in your case and see if temps improve when you open the case.
kaan3215w14dd02cb
it changes only 2 degrees celcius. The airflow in my case is not that bad. Should i send my graphics card to the technical service?
Of course not. temps are normal. Most likely fresh thermal paste would give it an extra cooling buff. Still there is nothing to worry.
