msiforum.tkv5153202d4
- Oct 1, 2024
What is the max resolution for the DisplayPort with the X870 motherboards?
The spec sheet says 3840x2160@60Hz, but that seems low for the DP1.4 standard, DP1.4 HBR3 should be able to do 5120x2880@60Hz.
I want to chain 3 displays with MST for a total resolution of 7680x1440@60Hz, but I don't know if this is possible with the new motherboards.
The CPU I use in the 9950X, will I be able to do 5K@60HZ with the new motherboards?
