Issue Booting to BIOS
cgowera155002db
Since I have gotten windows 11 and tried to play a certain game it gives me an error message that I need "tpm 2.0 and secure boot enabled" but I can't access these settings. When I try to enter BIOS(by spamming the delete key) to fix these problems, it just goes to the windows sign-in screen like usual. I have tried all of the other possible "BIOS" keys and none of them work.
doug.hogart153b02d9
Active member
You have not said which motherboard you have, but some motherboards have a feature called GO2BIOS (if enabled) where if you have the system powered off, you can try holding down the power button for about 5 seconds to boot into BIOS. Otherwise in Windows 11 you should be able to try something like Settings-System-Recovery-Advanced Startup-Troubleshoot-Advanced-UEFI Firmware Settings
Pro
In Windows, open the Command Prompt with admin privileges, type the following and hit Enter:
shutdown /fw /r
Then when you tell us your board model and BIOS version (it's all listed in the BIOS), we can give you more advice.
With a lot of recent boards, all you need to do is perform a BIOS update (takes all of 5 minutes) and the firmware TPM 2.0 and Secure Boot will be automatically activated afterwards.
cgowera155002db
I have the PRO B660M-A DDR4 motherboard
cgowera155002db
shutdown /fw /r
I have the PRO B660M-A DDR4 motherboard and the BIOS version is E7D43IMS.100
cgowera155002db
Ok I seemed to have fixed the problem, I held delete button after restart to get into bios then I installed default keys or something then it allowed me to enable secure boot. Thanks for the help guys!
Pro
You need to update your BIOS. You have the oldest BIOS version which had a lot of known bugs. Many of them are fixed in the newest BIOS, and it also enables Secure Boot by default. Even though you have solved the Secure Boot issue, i would highly recommend updating the BIOS now too. You have to do nothing other than the following (and then maybe enable XMP for your RAM, so it runs at the proper speed):
1) Get the latest BIOS. It's the topmost one on the MSI support page for your board. https://www.msi.com/Motherboard/PRO-B660M-A-DDR4/support
cgowera155002db
Thanks, this solved it all just as you said! Easy to follow the instructions.
