Issues on MSI Claw 8 ai+
Blowdy
Hi everyone, I noticed a few small problems with my msi claw 8 ai+.
Yesterday I did a factory reset of my handheld console because I had quite a few similar issues.
1: In the power settings my power plan remains on normal mode, I have no other plans available. Yet in the battery settings I selected better performance.
2: I want to set the energy saver to 10% when the battery is low, except that I don’t have an option to change it when I used to be able to do it, now it stays at 30%.
3: Every time I launch msi center M launches, mystic light turns back on by itself even though I disabled it.
4: A notification appears every time the console starts, telling me that Intel automatic overlay has failed.
5: When I put balanced performance in the power settings when the console is in portable mode, every time I reboot it goes back to best performance mode on its own.
6: My msi Claw 8Ai+ has a problem, if I sometimes restart it my windows 11 bug. The task to open a new desktop (virtual desktop).
Am I the only one with these problems or do others have similar things ?
Thank you.
Did you solve the problem after factory reset?
For item 5, I know that when you set the user scenario to manual mode, the power settings will be changed to performance mode automatically.
So you may switch the user scenario to AI engine instead.
