S
scottg26
Guest
Great board so far
except for this few problems:
1. I cannot get the HDD light to work. I have one Seagate 120GB Serial ATA drive plugged into the VIA SATA port. If i turn the HDD light plug around the other way then the power light doesn't work either
. any ideas on to how i can get this to work?
only parallel drive i have is LG-4040B dvd writer, on secondary master.
I have also disabled the promise controller as i'm not using it.
2. i bought the Thermaltake silent boost k8 CPU cooler. Corecentre reports 49/50 degrees celcius idle and 56 at full load. thats a bit high isn't it? However the heat sink doesn't feel that hot, and the case has lots of ventilation (Lian-Li PC65) (i.e. is the temperatured being reported correctly?)
3. also Memtest doesn't work. it boots from floppy, and i can see it's interface for a split second before it reboots the pc...
4. BIOS (i flashed to 1.1) doesn't report ANY fan speeds
5. Even though i plugged the PSU fan speed cord into the mobo, nothing anywhere shows me it's speed (whats that extra cord for anyway? i plugged it into the psu_fan 1 on the motherboard) . same with one of the case fans.
6. Thats about it
all in all it is a very fast board, and these issues are very minor, but would be nice if i could get them fixed
Thanks,
scottg26
Specs: Athlon 64 3200+
MSI K8T Neo Bios 1.1
2x 512MB Winbond RAM with PSC chips
Thermaltake Silent Boost K8 CPU Cooler
Thermaltake 420watt PSU (3.3/5V = 220w)
PowerColor Radeon 9800 XT (Overdrive enabled)
SoundBlaster Audigy 2
LG 4040B DVD Writer
Seagate 120GB Serial ATA Hard Drive
Floppy Drive
Lian Li PC65 Case (Silver/Aluminium/Window)
I love the onboard LAN, never had it before on my previous motherboards ( i have the fully featured version of the motherboard)
. any ideas on to how i can get this to work?only parallel drive i have is LG-4040B dvd writer, on secondary master.
6. Thats about it
Thanks,
scottg26
LG 4040B DVD Writer
Floppy Drive
