- Jul 3, 2002
Hi dude's,
There are some older K8N Master boards that do not do C&Q properly with new CPU's.
Those boards need a rework.
If your board turns off when selecting Laptop or Minimal power option in Windows energy settings, then you have this problem.
You either RMA the board or when you know how to solder you can do it yourself.
If you solder nicely you won't lose warranty.
(Don't do this if you are not a sodering expert!!!!! then just RMA)
What you need to do is remove Q123 and Q124.
I will attach pictures so you know where they are.
If you don't care about Cool&Quiet, then don't bother.
BIOS 1.21 or later is required before you attempt this!
