M
Maximus[X-D]
Guest
K got my Msi and athlon64 3200 in yesterday swapped it into once of my spare cases and fired her up.
K, First problem i encountered was it would not boot off my 2x512 corsair pc3700 twin X ram.
then it would not boot of my Geil pc4000 2x256 Low latency (2.5,7,3,3)
I would boot off Hynix cheapo ddr400 stick. i then tried to manually set timings incase spd did not detect properly to no avail no matter what combination i used my top ram would not work.
I then tried a set of 2x256 Hyperx pc4000 modules. The booted and tested out fine.y
MSI needs to fix this glaring problem if your board doesnt work with Corsair top of the line Ram your A$$ out!!!
K after the ram fiasco every single thing went smoothly windows install as well as installing the useful utilities off the cd like MSI Core to overclock in windows. Windows and all utilities and updates installed without a hitch.
my spare 9800 pro installed without a hitch.
i then set about doing some quick benches.
i was getting, at stock settings,
3000 ish sandra memory bench
6044 3dmark2k3
49 fps Halo -timedemo (1024x768x32 all high no aniso or AA)
then i bumped it up to 220 which puts me at 2200 mhz
sandra went to 3350 ish
6360 on 3dmark2k3
58 fps same halo test.
i clocked my 2.6c p4 to 3.2 at 246 fbs with the corsair pc3700 2x512 at 3,8,4,4 1:1
i get about 5700 sandra mem bench
6038 3dmarks 2k3
48 Halo bench
even at default the xp3200 without being fully tweaked overtakes my 3.2 p4 at 246 fbs with 1 gig tweaked ram. Then when i overclock the hammer to 2.2 its pulling away pretty healthily. i suspect a stock 3.2 at 200 fbs would get trounced.
my testing was done with 2 9800 pros both clocked at 400/350 ( my main card will do more but to keep testing even i used the top speed of the slower one) using omegas latest cat 3.8 leaked drivers and default settings.
The good: So far this board has been easy to work with and setup, exhibiting great stability and performance.
Cpu running great temps under load using the stock retail heatsink. 53c loaded with Prime95 for 3 hours. Overclocking potiential seems to be good with these chips and the feature set is great.
The Bad: Will not allow the use of todays most popular and best Ram vendors top of the line products. Msi has to fix the issues with Corsair ram and that of Geil as well this is not the cheapo Geil either.
overclocking hits a wall at 220fbs i changed nothing went straight to 220 with what through initial testing appears to be complete stability however at 221 and above displays complete random instability, this tells me MSI is going to have to include pci/agp locks for this board to stretch its legs. i believe my chip has much more to offer.
Core windows tweaking and overclocking utility does some crazy stuff i cant move my vcore past default with it.
This is real preliminary i will see if i have to turn down from 220 to run my raptor raid 0 array of the SATA controller i should have more detailed information this weekend.
Does anyone know any other good places to share/compare MSI products at? also things like beta bios's or MSI sponsered forums ect?
M*Xi
6044 3dmark2k3
6360 on 3dmark2k3
6038 3dmarks 2k3
48 Halo bench
M*Xi
