k8t Neo - VIA / Promise Sata controler problem
E
edryhten
Guest
I just got two k8t neo boards in and am in the process of setting up two identical machines.
One machine the via sata controller will not recognize my drives. The Promise sata controller has no problem seeing the drives. Any ideas on why the via controller won't see the drives? I've even taken the hard drives / cables from the other machine and still the via controller won't see the drives.
I'd like to use the via controller at this point because one machine is allready setup and using it and i'd like both machines to be identical.
Thanks for any help
