Katana 15 B12VGK Main Fan Noise
I think the Main fan on my Katana 15 B12VGK is dying. It's pretty loud when spinning at a normal speed and makes a high squealing noise when spinning at the highest speed. I've blown out any dust and debris from the heat sink/fan assembly but the noise persists. Does anyone know where I can buy a replacement for it or what the part is called. Looking at the pictures I can't tell if I'd need the place the entire heat sink assembly or if the fan can just be replaced. Thanks!
Cannot see the attachment.
But kindly recommend to contact MSI support for replacing thermal module.
