Katana GF66 11UG-090XFR with USB-C to Display port 1920@240hz ?
pixelmania159602e3
I have recently bought a Katana GF66 11UG-090XFR laptop
I need to plug my monitor 1920@240hz G-sync on this one... how ?
With a usb-c to Display port ?
Thx !
zipper.sippola
FIRST LIEUTENANT
From a review: With only 3 USB Type-A ports and a single USB Type-C port, the connections of the Katana GF66 are quite limited, particularly since the USB-C connection does not offer any Thunderbolt or PowerDelivery functionality. This means that the HDMI connection on the right side is the only option to connect an external display. You also have to do without an SD card slot in the MSI gaming laptop. So it's a dud.
pixelmania159602e3
The usb-c cannnot be used to plug an usb-c to DP ?
