KATANA GF76-12UC-061TR F3 not working
yuzucual15cf02ef
Where can I get the system restore windows file for the above-mentioned model laptop?Jul. f3 is not working. And I want to integrate it back into the system. I want the laptop to go back to the way it came out of the factory. Thank you for your help.
Downey Rob
Active member
Did you have any error message or where you are stuck while perform F3 recovery?
If the recovery parition is deleted, it is not able to perform the recovery completely.
yuzucual15cf02ef
The rescue section does not appear. I think I completely deleted it in the factory settings. My music analysis program was shutting down without any error messages. For this reason, I chose to reset it from the system settings. I think the recovery section was deleted at this time.
Downey Rob
Active member
If it is deleted, it is normal that you can not perform F3 recovery.
Do you mean the whole system shutdown or music analysis program was crashed?
What music analysis program do you use? Do you only have this problem if you use this software?
