KT3 Ultra-ARU MS-6380ATX Temps
  • Thread starter Thread starter lugen
  • Start date Start date
L
lugen
Guest
I'm getting temps on the CPU and MO Board @ 125- 130 degrees F. Is this normal? I have all fans connected properly and a Volcano 7 with Radio Shack Heatsink paste. I removed power supply and have it sitting away from the case withthe case open. (Actually it is @ 115 degrees F with the case open) Any tips?
Lee
:O That would be 51-54C- just ducky. San Diego has been a little warm of late, so my temps (full load w/boxed AMD cooler) have been between 57-63C. If AMD says I shouldn't worry, then I won't worry.
KT3 Ultra ARU using onboard sound
2000+XP w/512 Meg Samsung 333DDR(tweaked)
64 Meg Radeon DDR
etc...
I'm currently using 2 case fans (one in and one out)
to circulate the air in my case
Your temps look fine to me....
As my XP-1700 does the same.....
I shouldn't worry, as this board has the CPU-overheating-protection-circuit.....
If all is running fine.... :]
I run a AMD 1700+ OC to 1800 via Bus increase. My case temp is between 70-85(max) and my CPU is between 111-120(max). I live in Tucson and the temp outside today is 107 and I DON"T have AC either - I have a swamp cooler X( Your system seems kind of high in temp. I run a Antec SX-830 Tall tower with two intake fans( antec) and to exhaust fans ( antec ) and a PS fan. CPU is a full copper heatsink with a 7000rpm fan.
How many fans are you running and what kind of case to you have. Also I have zip tied all my cable away for maximum air flow( case cover on ).
