Lan Drivers for H61M-P23 B3
bschmitt13
CORPORAL
I've installed the H61M-P23 B3 and Windows 7. It doesn't find the LAN (enabled on the Motherboard). The last step in the quick install instructions state that I should install the applications, presumably including drivers), but I don't see a disk anywhere. I tried the Atheros drivers, but install reports no Atheros found. How can I find the LAN?
What do you mean?: "but I don't see a disk anywhere." You don't have the disc that should have come with the MB or what?
That is correct. I've gone through the boxes and do not see a disk. Is there anywhere I can download the files or an ISO image from?
My apologies to all. Apparently a nominal amount of adhesive on the packing material was enough to hold the CD in place as we moved it to look. The disk is installing now. I hope I haven't wasted too much of your time.
Thank you.
Well, I would like to add that this is my first experience with MSI and I'm quite pleased with the prompt, pleasant, and professional answers. I posted twice today, received assistance almost immediately, and can move onto other things. Refreshing, indeed, and thanks, again.
