I'm on my second one of these motherboards and they both exhibit the same fault with the same workaround. On boot the primary LAN devices are not visible in the device manager under Vista, sometimes both LAN devices can vanish. I can get them back by shutting down and clearing the CMOS using the button on the board. I thought it was a Vista issue but if I boot a standalone backup environment, Linux based I think, that can't see the LAN devices either. I think the effect seems to be triggered by running any non windows environment, Acronis or Paragon backup seems to sometimes trigger it. However I have seen the devices just disappear when windows was running.
I did find an entry on a German website, from what I could understand there was a similar issue with a similar board and a BIOS upgrade fixed it.
I have logged a case with MSI, I'll let you know how I get on.
