Laptop fan coil whine
preyasverma
I've started experiencing coil whine from my laptop fan, after I gave my laptop for HDD replacement to MSI service center. What could be the reason for this and how can I fix it?
Big mac
Big mac
SECOND LIEUTENANT
Try to mute the speaker to check if the problem comes from the speaker.
Or go to Bios > Advanced > Set “CPU C states “to Disable and check the problem again. (Laptop reboot and press [DEL] continually)
