LAPTOP FAN MAKING GRINDING NOISE
jarjisalam115ce02e1
My laptop fan is making grinding noise.I don't think any part is broken or melted after just 8 months of usage. I have a MSI BRAVO 15 laptop wit these specs:
Device name MSI
Processor AMD Ryzen 5 5600H with Radeon Graphics 3.30 GHz
Installed RAM 8.00 GB (7.38 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Whenver my fan is switched on it is making grinding noise. I have to turn off my fan to get rid of the sound.I am not using COOLER BOOSTER FUNCTION.
PLEASE HELP ME!!!
Downey Rob
Did you try to update the latest BIOS and perform EC reset to re-detect the fan module?
It is also suggested to provide the video for noise sound problem.
LaptopHaver
If it's only 8 months and it's not a software issue, I'd probably just send it back in under warranty, especially if it's a sound that's easily replicated.
Two options 1. Buy new fan 2. Remove the old fan, clean the shaft with compressed air, then add a very tine drop of machine oil. It will regain a 100% of functionality and the noise will disappear.
