Less Processor Speed
hakanay.it155a02d9
Hi
I have GP76 Leopard and the processor is Intel-i7 10870h 5 GHz / RTX 3060 / 1 TB SSD / 16 GB Ram. However, when I enter the system information, or MSI Dragon Center it seems 2.2 GHz. Also I did a stress test but it seems that maximum of 4 GHz has been used. I believe all of the drivers are up to date.
How can I solve this problem?
next3r
MAJOR
5GHZ one core .,.low usage "still limited by PL ,.,.current" others setup - temperatures ?
or base clock lock -- cpu state under 95./: - power shcheme
HWINFO + sensor
edit full clock list
hwinfo/main/ CPU / cpu info tab -- all clock
4x cores -4ghz
1x -5ghz
6x - 3.6ghz --example
X heavy stress -- EDP limit or PL "power" or PROCHOT -- HWINFO + SENSOR + your stress
on AC/DC all time 90-100./. recharge cycle --full power
hakanay.it155a02d9
Dear next3r,
I am sorry but I could not understand the things you have just said. But I have installed the program that you shared and here are the results.
next3r
MAJOR
Dear next3r,
second
edit .,,.this 900MHZ min -- this mean NO LOAD - SPEEDSTEP "power save .-.-adaptive power "
or on LOCK -must have 4.5ghz MIN/MAX or in stress check SENSOR --example
translation is OK ??
next3r
MAJOR
Could you explain for a person who does not have too much technical knowledge?
try your stress ,.,.+ check single cores in SENSOR --HWINFO
HWINFO + sensor contains all .,,.when get in strees clock drop or limit "2.2ghz"
check CPU limit reason - temperatures //or power or EDP
for idle // balanced power scheme is normal --cpu is adaptive
range 0.8GHz-5GHZ ,.,.hight performance sheme --static lock 4.5ghz all cores -5ghz one core
edit
.,,.check your SENSOR -- HWINFO
next3r
MAJOR
example for create LOG ,.,.send here FILE
but must run LOG in your STRESS --where get problem
next3r
MAJOR
or this zone you must check in your system / stress
actual CLOCK for all cores
temperatures problem
other "LIMIT REASON"
edit
any custom SETUP for CPU ?? undervolt ??
next3r
MAJOR
and additional is PROFILES in DRAGON CENTER !
CPU LOCK
next3r
MAJOR
I cannot ssend the log file because it is too large. Can you give me email smt.?
next3R@seznam.cz
gpu mode -- MSHybrid intel igpu // d-gpu OPTIMUS "optimal"
or native -- only D-gpu "max performance" but more power hungry
for absolute max CPU potencial -- only D-gpu is better "but i thing OC or similar usage only"
next3r
MAJOR
here is my information
overheat is reason for limit
edit .,,.ideal full screen -- LIMIT REASON
and disable EC support in HWINFO --this create problems
HWINFO-setup from tasbar icon .,option .,,.SAFE/EC support - disabled
next3r
MAJOR
open the tray the whole - it will tell you exactly where the problem is, but the temperatures are high
next3r
MAJOR
here upload LOG ,..,email still not did not come
basic CPU limit -- DRAGON CENTER
CPU PROFILES ,,. unfortunately I don't use it ,,. so I advise blindly
SILENT or CONFORT profile ?? for CPU -- CPU lock on lower CLOCK "but around 90C - this is ideal"
or must set custom fan curve "faster" full RPM around 90-94C - TURBO profile in DC // custom fan curve
edit
