TURBO or NOMINAL CPU -- 5ghz one core /4.5GHZ all core load
on full battery + AC all time
but usage is limited ,.,. there depends on the use " my recommendation is not to use CPU above 90C "
custom fan curve // or CPU LOCK .,.,any new "working" LIMIT for 100./. usage or where you will arrive 100C in second
but it depends on usage
,.,translation
,.,.best reset statistic in HWINFO .,..,run LOG in your games or similar usage --check results
or all in SENSOR "this run in background" check all after gaming
