steven.blanchar15ca02e7
- Apr 19, 2023
I just received the dual liberators I kickstarted and came across an issue that I was wondering if it was something on my end or a bug in the software/firmware. I have one liberator plugged into the other and then the other plugs into the computer. My problem is that the one Liberator plugged into the other has an issue with its left button. Whenever I press it, it acts like its being held down and is spamming the key assigned to it. So if its assigned to 1 and I press it once I just get 1 being spammed like 11111111. Once I press any of the other Liberator buttons, it stops spamming the key. I tried changing the key it was assigned to and it didn't fix it. I tried swapping which Liberator was the primary one hooked to the computer and which was the secondary hooked into the other Liberator and it still gives the same result (the bad left button now works, but the good left button now spams the key). So I am thinking its an issue with the software/firmware, but wanted to see if anyone else had this issue before contacting their support. As it stands I basically only have 5 buttons to use as the 6th is just useless as is. So can anyone confirm this issue or is it just me?
