looking for help. gt780dx
sonsai
ok so here is my problem. I flashed a modified bios unlocked so that i could run my ram at the correct clock speeds.
after going into the bios and enabling the XMP setting my laptop will no long boot up.
the fan comes on
the power button lights up as well as the keyboard.
everything seems to work except the screen will not come on.
any ideas would be helpful
thanks in advance.
Maybe you pressed the turn off display button by mistake. Its in the touch screen on the top right.
