hinchuni14e302d1
- Dec 20, 2021
Hello, I just completed a (mostly msi) build and I love the aesthetics / performance so far.
I have the MSI EDGE z690, MSI Gungnir 100r, and the mag coreliquid 360r radiator cooling a 12900k. Temps are pretty good (24-30c idle). The case has two fans mounted for exhaust at the top; one in the back for exhaust, and the coreliquid 360r front mounted.
My biggest issue so far has been the NOISE; it's nuts. I checked the idle fan speeds in bios and it says the CPU fan is running around 500-600rpm, the system fans are running around the same 300-500 rpm, and the pump fan is running around 2700rpm. I'm wondering if the noise is that loud due to the case design or if it's just the fans. The case design is very open with more or less a metal barrier and a magnetic mesh anti dust strip between case and the fans. It's kind of annoying though watching back a video or music I'm now finding myself turning up the volume to drown out the fan humming noise.
Any suggestions would be great. I do have some other fans in my old system that I could try swapping in, but from what I've heard the MSI case fans are supposed to be decently quite (quick google search) so I'm not sure why mine are so loud. I put my ear around the case to see if I could locate a single source of loudness; but they all sound relatively the same loudness. Thanks J
