- Aug 10, 2015
My speed is at 4.550 ghz during a Cinebench run with pbo enabled. I sent the PC back to the store that built it, and they said they tried putting in a new CPU and putting the CPU on another motherboard with the same issue, so they called it normal. Are they wrong? I also tried the curve optimizer and got 4.6 MHz then. The motherboard is a b650 tomahawk max Temperature 78c
Here is what the store said:
Speed on the processor momentarily peaks at around 5 GHz across all cores upon arrival. All-core and stress tests usually settle around 4.55 GHz. Tested with another processor, and the processor was tested on another motherboard with equivalent results in terms of frequency. Different frequencies on all-core with different bios: the newer beta version gave high clock speeds but a low Cinebenchscore of 15500 points; the older beta bios from last spring peaked at around 17450 with Expo enabled. The current BIOS 1.70 gave 17280 points in the last test and was stable at start-up with us. Longer startup/boot, but nothing beyond what we normally see at 6000 MHz and AMD, tight settings, and memory training are done at every startup. The processor cooler was adjusted to "offset mode" for better cooling. No impact in terms of frequency or points was noticed from this.
If i can get someone from msi that can say that this is not normal i can use that as proof to the store
