Low Audio on H61M-P23
bschmitt13
CORPORAL
I think this may be the last question on my install of the on H61M-P23. Everything else seems to be working, The port on the back of the motherboard is "line-out". Connecting the un-powered speakers I have to it produces some sound but is difficult, at best, to hear, even with the sound turned all the way up in the Windows 7 Audio control. The audio connector from the front panel on the case has a connector for AC97 and one for HD Audio. (Azalia) and that manual includes a warning that connecting improperly can result in damage, so I'd like to get it right. If I plug one of those to JAUD1, can I plug my speakers into the jack at the front, and which should I use?
Thanks,
Bill
>>Posting Guide<<
Use the HD Audio connector.
You need powered (amplified) speakers to get better sound amplification. Using the front output will produce pretty much the same level of sound output. At best these outputs will produce acceptable sound levels for a headset.
