mht_sarikanary158202e1
- Jul 10, 2023
Low GPU usage and low FPS (RTX 4070)
Hello, I’m getting low GPU usage and low FPS every single game(except cs2 is around 90% (full setting and 170-200 fps which i think it’s low?))
It doesn’t matter what setting I’m using. I’m trying every game low/ultra, 1080p or 1440p, DLSS on/off. In low gpu usage down a little bit but fps stays same.
I try with every game I have(cs2, Apex Legends, Call of Duty, Rust, Forza, GTA 5) but I only have couple screenshots.
I run 3dmark Spy Test and while gpu is testing it hit 100% usage. But later today I run furmark burn test for 20 minutes, most of the time I got 100% and 210 fps but I realized sometimes it dropped 70% usage and when that happened fps down around 160.
Recently a well known youtuber from my area uploaded fps test for the same gpu and every game he got 99% usage and much higher fps(some of them same games I have)
I used my rig with GTX 1060 couple days after that I removed drivers with DDU and installed new GPU.
Delete everything can interfere gpu but nothing changed.
Installed clean win10 and win11 and nothing changed.
Updated bios nothing changed.
Turn off XMP nothing changed, put higher mhz nothing changed.
Try with 1080p monitor and 1440p monitor and both at the same time, nothing changed.
My previous rig had 100% cpu usage every time so I don’t think I have CPU bottleneck. And I know people are selling lower cpu’s with same gpu and there is no bottleneck.
The only thing isn’t new in the system is PSU.
I have 2 different GPU output from psu(not modular) and connected them into converter I got from inside GPU box(sorry for bad english
Only problem I can think psu is not enough but if so why I got 99% usage in test? (I’m not an expert just thinking)
My rig:
CPU: Ryzen 7 5700X
GPU: MSI RTX 4070 Gaming X Trio
MOBO: MSI B550 Gaming Plus
RAM: Kingston Fury Beast 32 GB 3600MHz CL18
SSD: Samsung 980 Pro 1 TB
PSU: 750W 80+ Bronze
OS: Windows 11 Pro
Monitör: 1440p 165Hz and 1080p 144Hz
Screenshots from rust and cod with on/off DLSS (fps wont change but you can see while it’s off usage is little bit higher)
)Only problem I can think psu is not enough but if so why I got 99% usage in test? (I’m not an expert just thinking)
My rig:
CPU: Ryzen 7 5700X
OS: Windows 11 Pro
