M480 Pro 2TB any firmware updates
eddi155f02dd
I was reading online there are some issues with the Phison E18 controller and there have been firmware updates for the controller, has MSI released any firmware updates for this nvme drive?
Update:
New FW updater is ready.
https://www.msi.com/Storage/SPATIUM...roduct=SPATIUM-M480-PRO-PCIe-4.0-NVMe-M.2-2TBThings to note before doing the update:
  • * Back up important data from the target M.2 SSD
  • * M.2 SSD must be installed to M.2 slot directly without any adapter
  • * Unzip the file and confirm both file is in the folder:
A. [MSI]M480 SSD update tool.exe
B. pcie_dll.dll
To proceed:
- Run M480 SSD update tool.exe with admin privilege
- Confirm target SSD is recognized by tool
- Run the update tool
- Restart PC
Result:
[Pass] tool will show “firmware download success”
[Fail] tool will show “firmware not support”
If SSD FW version is up to...
Hello, @Svet!
I have an MSI Spatium M480 Pro 1TB with Micron flash memory, EIFM31.6. Could you please send me the latest firmware update? Thanks.
Got it, thanks.
Noticed the 2TB Pro
Flash Memory Type Micron 176-layer 3D TLC NAND on the one that can't be flashed
On non Pro version of 2TB Flash Memory Type Micron 96-layer 3D TLC NAND
that can be flashed fine
Will be interesting to see the same report for 2TB Pro that was successfully flashed.
