M_1 Not present
Hey.
On Gen 5 Together with 2 x Corsair MP 700 PRO. Both in GEN 5 mode. I have 3 out off 10 restarts with no M_1 Present. Is it the CPU, the MOBO or the 2 x Corsair MP 700 PRO that is failing?
I hope for a bios update that fix this :)
Over and out:-)
  • Gen5 on M1 and M2.txt
Try to exchange M.2 slots of the 2x Corsair MP 700 PRO SSDs and see if the issue follows the specific SSDs.
Also set the M2_1 slot as Gen4 and check if the issue still happens.
Thx to both of you.
Goodspeed first.
Yes i have allready don that. as so far I get the same result.
And also try to set 1 at Gen4 and both on Gen4 and now something strage starting to happen.
1 issu is that the M2_2 sometime still stay in Gen5 mode and some time I get M.2_1 not pressent. and one more funny thing is that both off them sometime run and get into Windows but only in 950 MB/s thats like older SSD drive on SATA.
Alan J T.
Yes I started there.
Maybe in the Easter I will get enough time to try change the both the Corsairs MP 700 to my WD850X. Jsut to see if the same patten repeats itself.
