what is your windows version and os build??Not a firmware issue, currently running FW116 as well and HDR working fine in windows with both HDMI and DP
W11 25H2 (OS Build 26200.6899)what is your windows version and os build??
DAMN, why i am facing this problem -_-W11 25H2 (OS Build 26200.6899)
ever uninstall GPU driver using DDU?DAMN, why i am facing this problem -_-
yes. . .but after that i fresh install windows 11, bt no solution. . .ever uninstall GPU driver using DDU?
nah bro not AMD issue, I am using MSI RTX 5080 trio ( nvidia )I am also having the identical problem. Received monitor Nov 7 and HDR worked through DP port windows 11 with FW106. Updated firmware to FW116 and HDR shows not supported in windows. Have also updated driver in device manager and DDUed and updated GPU drivers. If someone has a copy of FW106 I can try and roll back to it would be appreciated to see if that would solve the issue. I cannot seem to find legacy firmware online. Using AMD RX 7800 XT it may only be an AMD issue.
I have FW106 thats why i am upgrading to FW116. . .Don't think it's a firmware issue FW116 works fine for my screen, did you guys flash the wrong FW? maybe you had FW020 initially and flashed FW116 instead of FW029? not blaming just curious.
I was very careful about that. I definitely had FW106 before upgrading. I have now been told by support to just wait for the next firmware release and hope that solves this problem.Don't think it's a firmware issue FW116 works fine for my screen, did you guys flash the wrong FW? maybe you had FW020 initially and flashed FW116 instead of FW029? not blaming just curious.
Any idea when the next firmware update is coming out??I was very careful about that. I definitely had FW106 before upgrading. I have now been told by support to just wait for the next firmware release and hope that solves this problem.
Not a clue.Any idea when the next firmware update is coming out??
btw another problem in FW116,I suggest you reach out directly to MSI.
>>How to contact MSI.<<
something weird with your FW flash, cause HDR works fine on mine and panel protect doesn't change like before either.btw another problem in FW116,
- Description:
1. Changing Protect Notice from 16 hrs to 24 hrs. ( FIXED )- 2. Fixed the default of Panel Protect will change back to 24hr option. (When the default of panel protect has changed to “Auto”.) ( NOT FIXED still having this problem )
- 3. Fixed in SDR mode, that switch the sub option of “DisplayHDR” will cause SDR brightness difference phenomenon. ( FIXED )
