Mag B550 crashing randomly
tourbu12b602a9
Motherboard: Mag B550 Tomahawk MAX wifi 7C91
Processor: Ryzen 7 5800X
Ram: G.SKILL Ripjaws V Series 64GB (2 x 32GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16D-64GVK
GPU: Zotac Geforce RTX 3070 ti Trinity OC
This is a new PC build. Everything on the computer works well until, after gaming for about 45mins -1hr the computer will randomly crash. I have updated all my drivers, updated windows, the motherboard is on the latest firmware. I have tried other ram and done a second clean new install of Windows 11. It always results in the same problem.
Event 46, WHEA-Logger
A fatal hardware error has occurred.
Component: Memory
Error Source: Machine Check Exception
The details view of this entry contains further information.
I have tried everything I can think of to fix this, and I am beginning to think I got a bad motherboard.
Are you able to recall what was going on when / just before the game crashed?
At the moment there are too many variables in play with the CPU and GFX card, both have a form of dynamic overclocking and if not working correctly can cause the game to crash. Both issues also operate in a way that means max power and heat stress testing can all pass with no issues. This is because at a constant load the CPU and GPU will also be at a constant frequency / voltage whereas during a gaming environment both are changing many times a second, the CPU/GPU frequencies and voltages will be all over the place.
So for the purpose of fault finding it's best to control the CPU and GPU.
- CPU is easy, you simply fix the frequency to the base clock of 3.8GHz. (In the BIOS set the CPU ratio to x38) and try gaming again.
- GPU swap out or limit the boost clock using MSI afterburner software.
once installed -500MHz from the GPU, make sure you click the apply button.
Thank you for this suggestion, I am hesitant to report this as I may curse myself. But I tried the CPU fix in the bios, and my issues seemed to stopped all together. I don't know if I have played long enough chance to really test it out, but I have played 3 different games for over a hour, and one game for over 3 hours and none of them crashed. Temps all seemed good. Maybe its fixed?!?
So x38 CPU ratio, keep playing :-)
While you do that can you also use hwinfo to capture the peak temps (max temps), and what games are you playing?
For example cyberpunk after 30 mins with a screenshot of hwinfo (show everything like you have done before)
This is important as if the CPU is at 3.8GHz and peaking at 80 Deg C it's not good.
