MAG B550 TOMAHAWK - USB ISSUES
ante.budimi15bd02e2
Hello, I would like to ask, I have a computer that is about half a year old.
MB – MSI MAG B550 TOMAHAWK
CPU – AMD RYZEN 7 5700X
VGA - MSI GeForce RTX 3070 GAMING Z TRIO 8G
HDD – SAMSUNG 980 PRO
RAM - KINGSTON 2X16GB DDR4 3200MHz CL16
WIN – WINDOWS 11 HOME Version 22H2
BIOS – E7C91AMS.AB1
CHIPSET DRIVER - 5.01.29.2026
I have problems with some USB flash drives, when I plug them in sometimes they don't even load, I have to repeat it several times. Sometimes the computer tells me that the device was not recognized. They are mainly flash drives ordered on AliExpress BIYETIMI, but CORSAIR FLASH VOYAGER also annoys me. Of course, I tried other usb ports, but it was the same. I was also annoyed by the scanner, connected via USB, which kept connecting and disconnecting, or the mobile phone with a longer cable. Everything worked fine on my old computer. I also wrote to MSI support, they advised me to adjust some settings in the BIOS (Global C-state Control – Disabled, Power Supply Idle Control – Typical Current Idle, Resume By USB Device – Enable, Wake Up Event Setup – Disable, adjust the chipset gen to gen2 manually to try), but nothing helped. I also tried running Linux UBUNTU from a flash drive and everything seems to work there. Does anyone have a similar experience? Thanks
Nichrome
Friday? Deploy to prod!
Hi
Lets put aliexpress trash aside. I wouldn't ever plug that in.
Other than Corsair flash drive, do you have any other USB related issues? Is the scanner, as well as the phone, connected using original cable?
Do you have these problems since you go this system, or it started to happen recently?
ante.budimi15bd02e2
Hi
I have had these problems since I built my computer. As for the flash drives, they work on another computer. I don't have the scanner connected with the original cable, nor the phone. I seem to be bitten by a mouse that is connected via USB (wireless). It seems to me that the USB ports are not very sensitive.
Nichrome
Was Windows a fresh installation on it, or moved over from previous system?
Nichrome
Ok that's very strange. Other than some potential issue with drivers, I've no clue what may be happening there. Maybe MSI support can help with this. >>How to contact MSI.<<
