haydnbaggaley
- Feb 9, 2019
I'm having two, possibly related, issues with booting up. This is a completely new computer save for a storage SDD.
CPU: AMD Ryzen 7 7800X3D
GPU: ASUS PRIME Radeon RX 9070 XT 16GB GDDR6 OC Edition
MOBO: MSI MAG B650 Tomahawk WiFi Gaming Motherboard
RAM: Lexar Thor Z OC DDR5 RAM 32GB Kit (2x16GB) 6000MHz CL36 Desktop Memory
OS SDD: Lexar ARES 1TB SSD M.2 2280 PCIe Gen4x4 NVMe 1.4
PSU: CORSAIR RM850x
1st:
My M2 OS drive will randomly not be recognize motherboard. In the bios it will either show as a generic drive no information, or not be seen at all. In both cases I can;t boot to it.
I get around this by moving the drive to a different slot. But it seems to be a matter of boots before it happens again.
2nd, much bigger and weirder issue.
Computer will lock up at boot after a power off when the GPU is in. No issue when I only use the motherboard video. Restarting is no problem. Every time time I do I cold boot the system will lock up. eeze debug lights will display red and orange. I understand this either means mobo can't detect CPU and RAM, or it's stuck in memory training. Leaving the computer alone t memory train doesn't help.
To boot again I have to clear the CMOS via removing the battery, this requires removing the GPU. The jumper option has not worked for me yet. After clearing the CMOS, I can reinstall my GPU and boot once. Once into windows everything works fine.
I know it's not the ram because it with both and either of my ram sticks, and which slots I use.
Moving the GPU to the lower PCI-e slot didn't stop the issue, but only the RAM eeze debug light turns on. So i'm pretty sure it is related to how the mobo talks to the GPU, as the lower PCI-e slot doesn't have a direct tie into the CPU like the top one does. I know my GPU isn't to blame because this happens with my old GPU as well.
I have tried a bunch of different settings in the BIOS to no avail. I've tried several different BIOS updates, no change; except for switching to GEN3, which some how got me a single bonus cool boot.
I feel like this is a soft/firm ware issue. I am hoping there is some obscure bios setting I can hit to avoid the issue until a new BIOS update fixes it permanently.
Any Ideas?
PSU: CORSAIR RM850x
1st:
Any Ideas?
