MAG B850 TOMAHAWK MAX WIFI + Ryzen 7 9800X3D + RTX 3070 Ti - nvlddmkm Event ID 153 / GPU timeout
alsi496
Hello
I am experiencing intermittent GPU-related system instability on my MSI MAG B850 TOMAHAWK MAX WIFI motherboard.
My system configuration:
  • Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI (MS-7E62)
  • CPU: AMD Ryzen 7 9800X3D
  • GPU: Palit GeForce RTX 3070 Ti GamingPro
  • PSU: DeepCool PQ850M 850W
  • RAM: DDR5 32GB, currently running at JEDEC 4800 MT/s (EXPO disabled)
  • BIOS versions tested:
    • Previous BIOS: E7E62AMSI.2A62
    • Current BIOS: 7E62v2A64
Problem description:
During gaming (mainly World of Warcraft, but also observed in other situations), the system occasionally experiences a GPU timeout:
  • The image freezes for several seconds.
  • Sometimes the screen briefly disappears and recovers.
  • Sometimes the GPU driver recovers automatically and the system continues working.
  • In more severe cases, the system requires a restart.
After recovery, Windows Event Viewer shows:
  • Source: nvlddmkm
  • Event ID: 153
  • Message:
    • \Device\Video3
    • Error occurred on GPUID: 100
There are no WHEA errors.
CPU and memory stability tests pass.
GPU temperature is normal.
VRAM tests pass.
Troubleshooting already performed:
  1. Clean NVIDIA driver installation using DDU.
  2. Different NVIDIA driver versions tested.
  3. EXPO disabled.
  4. RAM tested at default JEDEC 4800 MT/s.
  5. GPU tested in another PCIe slot:
    • Secondary PCIe slot
    • PCIe Gen3 mode
    • Power Limit reduced to 80%
  6. Main PCIe slot tested with:
    • PCIe Gen4 forced manually instead of Auto.
    • ASPM disabled.
  7. NVIDIA Control Panel:
    • Power management mode set to “Prefer maximum performance”.
  8. CPU NB/SoC Voltage was tested manually at 1.25V.
  9. GPU power connection verified:
    • Two separate PCIe power cables from PSU to GPU.
None of these changes completely eliminated the issue.
After updating BIOS to 7E62v2A64, I tested the system with completely default BIOS settings:
  • PCIe settings Auto.
  • EXPO disabled.
  • RAM 4800 MT/s.
The system appears more stable so far, but I need to confirm long-term stability.
My questions:
  1. Are there any known PCIe compatibility issues between MSI B850 motherboards and older PCIe 4.0 NVIDIA GPUs such as RTX 30 series?
  2. Does BIOS 7E62v2A64 contain any PCIe/AGESA fixes related to GPU link stability, PCIe power states, or nvlddmkm recovery errors?
  3. Are there recommended BIOS settings for this motherboard when using RTX 30 series GPUs?
  4. Could this behavior be related to PCIe link training, ASPM, CPU I/O/SoC behavior, or AGESA firmware?
  5. Are there any diagnostic logs or tests you recommend to determine whether the motherboard PCIe subsystem or the GPU is responsible?
I would appreciate any guidance or information about known issues with this platform combination.
Thank you.
Based on everything you have tested and the history of the board itself... I suspect it's the Motherboard. It's had issues with Nvidia GPU's before, the PCIe would run at gen 1 speeds after suspend / boots causing the whole system to chug and be stuttery. It took them a solid 6 months or so to fix it ( I never saw them ack that it was an issue anywhere other than a tiny description line in one of the BIOS updates "- Improved PCIe-based devices compatibility under certain CPU or system combinations." ). For whatever reason their QA seems to have missed a lot of testing with team green's GPU's... though to be fair Nvidia's drivers this year have been flaky, maybe they're having a hard time pinpointing actual issues with all the noise.
Hi OP, about a year ago I experienced the same issues. I first noticed them when black boxes started appearing in YouTube videos within my browser; later, games would crash randomly. In my case, it wasn't a BIOS update—I’ve been using version 7E62v2A40 since the very first boot. In my case the problem was caused by an NVIDIA driver update. I have an RTX 3090 with same motherboard (MAG B850 Tomahawk Max WiFi MS-7E62) and a 9950X3D processor. I fixed it by booting into Safe Mode and running DDU (Display Driver Uninstaller), then restarting without an internet connection, installing an older version of the NVIDIA driver, and only then reconnecting to the internet.
If that doesn't solve it, it’s also possible that your graphics card is on its way to past out (die)
