MAG B850 TOMAHAWK MAX WIFI - TPM Firmware 6.33.0.6 causes FAILED ATTESTATION in Call of Duty (Warzone / BO7)
I'm experiencing an issue with my MAG B850 TOMAHAWK MAX WIFI (E7E62)
related to AMD fTPM firmware and Call of Duty's anti-cheat system.
System info:
- Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI (E7E62)
- BIOS: V2.A61 (AGESA PI-1.3.0.1b) — latest available
- TPM Manufacturer Version: 6.33.0.6
Issue:
Warzone and Black Ops 7 use TPM 2.0 attestation via enrollaik.exe
as part of their anti-cheat. According to Activision's official
support page, AMD TPM firmware versions matching the pattern X.XX.0.X
(third digit = 0) cause a FAILED ATTESTATION STATUS error and prevent
the game from launching.
After updating to the latest BIOS (V2.A61), the TPM firmware remains
at 6.33.0.6. Activision explicitly states this requires a BIOS update
with a newer AMD PSP/fTPM firmware to resolve.
Is MSI planning to release a BIOS update for the B850 TOMAHAWK MAX WIFI
that includes an updated AMD fTPM firmware (6.33.1.x or higher)?
This appears to affect many users on AMD 800-series boards. Any ETA
or confirmation would be greatly appreciated.
Thanks
>>How to contact MSI.<< for ETA. It also helps MSI keep track how many people are affected.
Activision should kindly stuff these anticheats up their.. noses.
Salut,
Je rencontre un problème avec ma carte MAG B850 TOMAHAWK MAX WIFI (E7E62)
lié au firmware AMD fTPM et au système anti-triche de Call of Duty.
Informations système :
- Carte mère : MSI MAG B850 TOMAHAWK MAX WIFI (E7E62)
- BIOS : V2.A61 (AGESA PI-1.3.0.1b) — dernière version disponible
- Version du fabricant TPM : 6.33.0.6
Problème:
Warzone et Black Ops 7 utilisent l'attestation TPM 2.0 via enrollaik.exe
dans le cadre de leur système anti-triche. Selon le communiqué officiel d'Activision
Page d'assistance, versions du firmware AMD TPM correspondant au modèle X.XX.0.X
(troisième chiffre = 0) provoque une erreur d'état d'attestation échouée et empêche
le jeu dès son lancement.
Après la mise à jour vers la dernière version du BIOS (V2.A61), le firmware TPM reste
à la version 6.33.0.6. Activision indique explicitement que cela nécessite une mise à jour du BIOS.
avec un firmware AMD PSP/fTPM plus récent pour résoudre le problème.
MSI prévoit-il de publier une mise à jour du BIOS pour la carte mère B850 TOMAHAWK MAX WIFI ?
qui inclut un firmware AMD fTPM mis à jour (6.33.1.x ou supérieur) ?
Ce problème semble affecter de nombreux utilisateurs de cartes mères AMD série 800. Une date de résolution est-elle prévue ?
Toute confirmation serait grandement appréciée.
edit:
I'm experiencing the same problem with the same game. I have the motherboard below:
MSI B450M Mortar Max (LATEST BIOS)
Proc: Ryzen 2700x
Hope MSI helps us!
