R rafapdar156502db New member Joined May 14, 2023 Messages 2 May 14, 2023 #1 Is there a correct connection for the fans on the motherboard? Do I need to configure anything in the Bios after installing the water cooler?
teletubby_po To infinity and beyond. FIRST LIEUTENANT Joined Apr 6, 2020 Messages 2,200 May 15, 2023 #2 normally all you need to do is connect the radiator to the pump fan header, and 3*120mm fans to the CPU fan header. you can adjust the fan curve in MSI Center\User Scenario or BIOS settings\Hardware Monitor.
