rabidding15b002e6
- Mar 3, 2026
I have a newly built rig with the aforementioned motherboard running with Win 11, 64gb ram, amd 7 9800x3d, nactua NH-u12a, msi 5070ti
When going into the BIOS the CPU core temp and CPU fans are not being detected - the fans will show some RPM status a bit but then turn off - It does see the case fans in other sysFan slots. The BIOS does detect everything else without issue.
The MB is up to date on latest firmware. I've reflashed, updated, powered off for hours, I have tried shifting the pwm and dc settings to no avail.
When using the AMD center, and also when using FanControl - both of these see the core temp, and the fans correctly - so the system sensors are working.
Though seemingly the bios keeps trying to take over control after each reboot. (I have the smart fan settings disabled on the BIOS - set at pwm 100% *I also tried at 50%). If I re-run the calibration with FanControl the fans then re-read and work again.
Trying to see if there is a full BIOS firmware fix, or setting to shift. Old threads for FanControl show this was an issue with these cards previously but seemingly patched out a while ago. Any advice would be appreciated.
