sea11sid156102d9
- Apr 3, 2026
Has anyone experienced this issue with this particular motherboard (or equiv) in which the screwless M.2 Shield Frozr heatsink doesn't make good contact with the M.2 NVMe? I'm using a Samsung 990 Evo 2TB (Gen 5) in that slot, and when I close it, there isn't much resistance, so I'm suspecting that the heatsink isn't making good enough contact. The result is that the controller temp is 68c - 72c on idle, and when I run Samsung Magician benchmark, the temp goes in the red and I think starts to throttle. I contacted MSI tech support, and they suggested I RMA the motherboard so that they can test it. Ugh. I would suspect that many people would have this issue, given how popular the Samsung NVME drives are, so is there a simple fix I can make so that I don't have to take my whole computer apart and wait for a new motherboard (which will likely have the same problem)? I suppose I could order a thicker thermal pad, but not sure how thick it should be or if it's even worth a try. Recommendations much appreciated!
