zlayapipetk15c602eb
- Apr 5, 2025
System Configuration:
Faulting module name: CPU_Engine_x64.dll, version: 2.0.0.71, time stamp: 0x6747db01
Exception code: 0xc000041d
Fault offset: 0x00000000000070fc
- Motherboard: M/B MAG X870E TOMAHAWK WIFI
- CPU: AMD Ryzen 7 9800X3D
- Memory: G.Skill DDR5-6400 65536 MB PC5-51200
- Cooling: be quiet! PURE LOOP 2 360mm (BW019)
- Graphics Card: MSI PCI-Ex GeForce RTX 4060 Ti Gaming X Slim
- Operating System: Windows 11
- Unstable performance when temperatures exceed approximately 80°C+-, which is visually indicated by the temperature "freezing" on the LED display on the motherboard. This leads to the water cooling system running at full speed continuously, which can only be reset by rebooting the machine. Additionally, some system applications crash, and AMD Ryzen Master stops working.
- Memory settings were adjusted from 6000 to the base 4800 MHz and tested for 5–6 hours using Windows Memory Diagnostic and MemTest86 with no errors found. However, during one of the MemTest86 tests, the temperature sensor once again froze.
- MSI Center does not install correctly – on the HARDWARE MONITOR tab, only the GPU data is shown. Moreover, when the temperature "freezes," the application itself crashes, for example:
- It is possible to play a game without noticing that the temperature has frozen, and only realize it after exiting the game. Sometimes, the game itself may also crash due to this issue.
