MAG Z590 TOMAHAWK WIFI - pump header
scott_trahe100e027e
I'm building a rig with the Mag z590 Tomahawk WiFi mother board and adding a galahad 360 AIO radiator. The motherboard manual says it has a "1x 4-pin water-pump connector" in the Internal Connectors section on page 18 but I can only find the PUMP_FAN1 header. So I'm confused on which header i should use for the pump head and which header should i use for the radiator fan array?
Yes, this is the pump fan header they mean. It's more powerful than the other headers. A fan draws a lot less power than a pump. You can put the fans anywhere you like, and put the pump on PUMP.
