cjeffords831
- Oct 21, 2026
Hello MSI Community. I hope somebody can help me here. I've been searching through the forum and also doing web searches but haven't found anything definitive. I recently purchased a MAG Z690 Tomahawk WiFi DDR4 and an I7-14700K, hoping I could upgrade my gaming machine without having to spend $1,000 for RAM. I have 64GB of Corsair Vengeance DDR4 that I installed before prices skyrocketed, so I wanted a DDR4 motherboard.
What is the magic combination of acceptable USB stick and BIOS update file that I need to use in order to get this %$#&@&#$ BIOS to flash?
After I unboxed the motherboard, I thought I had successfully updated the BIOS using the USB port and Flash BIOS Button on the back panel. I started the process, then walked away for a bit, and when I came back, the red light had stopped flashing, so I assumed it finished. Then I built the new system, plugged everything in, and hit the power button, but nothing happened. I tried a few things while the system was assembled but couldn't get anything to turn on, so I started disassembling until I eventually got back to where I started, with the motherboard resting on top of the static bag on a cardboard box. I tried, unsuccessfully, to "hotwire" it by holding a screwdriver on the two Power SW jumpers, but that did nothing. Then I grabbed my voltmeter to see if the motherboard was receiving power. It was. When I touch the positive side of the Power SW jumpers, it shows 3.3v on the meter.
At that point, I assumed the BIOS update had failed so I tried it again. And again. And again and again and again. Each time I tried to flash the BIOS, I inserted the USB drive into the port with the outline that's labeled "Flash BIOS" , turned on my power supply, and pressed the "Flash BIOS Button".
For the majority of the sticks I've tried, the red led near the USB port flashes slowly (1 time per second, approximately), then continues to flash slowly for a few seconds, then goes into a steady blink of approximately 2 blinks per second. Each time, I've let it fast blink for 10 to 15 minutes. Last night, I tried to leave it alone for over an hour, but it was still fast blinking when I got back. For one stick, which is an 8GB SanDisk U3 Cruzer, the red led and the USB stick will alternate blinking for about 10 seconds and the red led in the EZ Debug LEDs lights up, then the red led will fast blink for a little while, then all blinking will stop after about 45 seconds. The most recent USB stick is a 1GB SanDisk Cruzer that contains a non-removable CD partition. I formatted it as FAT32 anyway and copied the MSI.ROM file to it, just to try it. On this one, the red light blinked solid for a few seconds and the USB disk did the same, then the red led started blinking approximately once per second and the light on the USB stick stayed lit. It has been in this state for about 30 minutes.
1. Each USB drive I have tried has been formatted as FAT32 with just the single MSI.ROM file at the root.
2. I have tried 9 different USB sticks ranging in size from 512MB to 32GB.
3. BIOS updates were downloaded from https://us.msi.com/Motherboard/MAG-Z690-TOMAHAWK-WIFI-DDR4/support. I have tried both 7D32v1O and 7D32v1N. Per the instructions I found, I rename the downloaded file to MSI.ROM (I've also tried lowercase msi.rom), and copy it to the root of the USB drive.
4. I pulled the CMOS battery 4 or 5 times during this process to try resetting everything to factory, but that doesn't seem to help either.
